k9-keno
Sep 15, 2013Explorer
2001 E450 SD Vacuum check valve??
Hello...I have a 2001 Ford V10 E450 running my class C and just this weekend we were driving and notice the fan for AC or Heat or vent will go from dash air to defrost when the motor is under stress like going up hill. If I let off the gas the air flow switches back to coming out the dash vents from defrost. I was looking around the internet and some have said this can be a Vacuum check valve located somewhere over the driver wheel well. Anyone have this problem before? How much is part?? How do you fix it?? Someone on the internet said you have to remove a ton of stuff to get to it and there are other methods of dealing with this problem. Motor runs fine no misses or anything just this issue. Thanks
