usersmanual
Nov 26, 2016Explorer
dougrainer wrote:
AS someone who has repaired Newmars since 1994, ALL the coax cables go to the front overhead where the Winegard multicoax box is located. IF you have the Winegard switch box, there is a inlet marked Cable. THAT comes from the outside Park Cable input. NOW, the problem is, odds are in the past 15 years, some idiot went in and moved all those cables around and did not label them. So, what you have to do is use a Coax cable finder and determine which of all those Coax cables are the Park Cable. When you state the Park cable system is NOT near the Main system you are correct. What Newmar did back then was to run the Park Cable to the Overhead(usually above the Pass seat). They then had another coax running from the overhead to the Winegard multi system. You then had a short 6 inch coax jumper that jumped the 2 coax plates in that overhead to the Front Winegard system. The REASON for that was, if you wanted to install a Tripod Sat dish, you could remove the jumper. use the Park cable to the Tripod dish and then the OUT TO TV coax to the coax feed to the Winegard switch box. Last, those 2 coax plates WERE identified by Newmar by stickers on the plate. Doug
thanks a bunch Doug ;;the 6-8 inch coax was missing;; once installed
all is well;; much appreciated
