Rving22650's avatar
Rving22650
2002 E.450 c.class starting issues
I have a 2002 e450 v.10 c.class with 26,000mi sat for 3 mo. Went to start it it back fired a couple of times then tried again it started ran kinda rough. Went out a month later it was supper hard to start would barely hold a low idle. Went out a month later even harder to start and if it did it was for a second or two. If I keep cycling the key 5 to 10 times eventually it might start for just a second and have a very low idle but if I touch the gas pedal in the slightest it dies. I changed the fuel filter,air filter. checked the fuel pump and its pumping out fuel at every key cycle. Checked the inertia switch its ok.not sure what else to try? Won't run
so can't take it to a repair shop.
