j-d's avatar
j-d
Explorer II
Jun 26, 2015
2002 E450 A/C Vacuum Loss
As in title, 2002 E450 under Class C.
A/C blows out of Defrost Vents Only. Vehicles are set up to use the Defrost Vents IF Vacuum or the Mode Selector fails.
I've found I have vacuum where the line to the controls connects under the hood. And NO vacuum at the Selector vacuum source connection. Had to take the entire dashboard "bezel" off to do this.
It seems Ford has buried the Vacuum Check Valve and Reserve Canister somewhere tricky inside the Dashboard/HVAC cabinet area.
Anybody been in there and found that stuff? Behind an Air Bag, by the way...
  • They are often hidden under the a headlight and in front of one of the front tires in the area that's usually empty. Sometimes you can look up from under the rig and see them.
