dalenoel
Jan 15, 2018Explorer II
Inside on the main switch panel you may find some switch labeled 'System Heat' with a light next to it. When you turn on the switch it will glow red. If the temp is low enough outside then the power will go to the heater and the light next to the switch will glow. This tells you the heater is getting power.
There is a snap switch between the inside one and the heater that will not turn on unless it is cold enough and will turn off to stop the heater if the bay is warm enough.
In your manual look for 'System heat'. It is only 40 where we are and it never came on last night. In Michigan it would come on but only raise the temp in the bay about 20 degrees.
