zach477
Jul 31, 2015Explorer
mcgyverdc wrote:
Everything worked perfectly, then went to start and nothing comes on when i turn the key...driving me nuts! Must be a master fuse or something
If it's intermittant, it's probably not a fuse. If the battery itself is showing voltage, it's not the battery itself...
I had a car that acted kind of that way once. I'd turn the key a little, things would light up, turn it further to start the engine, and everything would go dead. I'd go look under the hood, nothing looked weird, shut the hood....and it would work again. Turns out that the battery connections were bad and shutting the hood jiggled it back into working order. I had to clean/scrub the battery posts and cables and put them back on nice and tight.
Unless I'm misunderstanding your symptoms, it sounds like this could be the issue.
