Vulcan_Rider
Aug 01, 2015Explorer
mcgyverdc wrote:
yes understand the 2 different banks of batteries....starter batteries show 12.8v at the terminals....
I've been looking for the location of the "master" switch....and can't find it.....
Details are important.
Your responses don't exactly match some of the questions asked.
IF....the cable clamps are not making good connection, you can measure 12+ volts on the battery terminals but nothing on the actual cable ends that are attached to the posts.
So you need to measure the voltage on the cables, with the ignition switch turned ON.
Next test: Do the headlights and parking lights work?
If not, then you definitely have a battery, cable or main fuse link problem. If they DO work, then it's back to the ignition switch or fuse probably.
And I don't think anybody mentioned a "master battery switch".
I don't know what that is, in relation to the starting batteries for the engine.
There might be an emergency battery switch.....but there might not too.
I really think that your next move, in addition to the suggestions above, should be to try to jump it to another known good battery.
