Ivylog
Nov 23, 2017Explorer III
William Willard wrote:
On our 07 Camelot, there is a PC board in the rear run bay that controls the slides -- Bill Willard
A 03 Monaco does not have the multiplex system so it's rocker switches, fuses and relays. OP, you are not getting 12V to the pump motor. Could be the relay at the motor, a bad connection, or a blow fuse on the control circuit. Start by seeing if you have 12V to one side of the motor relay (located at the motor). Next check for 12V to the small wire that turns the relay on when someone tries to move a slide.
Related Content
- Feb 01, 2026Community Alumni
