tropical36
Nov 23, 2017Explorer II
tropical36 wrote:DaisyMaggie wrote:
All 3 slide outs on my 2003 Monaco Camelot stopped working at the same time. My front slides were out so I had to hand crank them in. Is there a circuit breaker anywhere that controls all slides? if so where would it be? Could there be any other problem that anyone knows about?
Sitting level?
Voltage up to par and should be around 13.2vdc?
Do they work with the engine running and this should supply the voltage required from the alternator if the batteries are down?
Shore power should supply what's required as well, but if there's a big boy relay or like crossover, that's not working and power is coming from the chassis batteries, then it might not have enough power. Try using your aux. start button on the dash, while you're at it.
Don't know of any system with a master DC circuit breaker and should each have a fused controller for each slide, so unlikely that all three would have a complete loss of power. However, on edit, I stand corrected after reading Bill Willard's post and his input, could very well be the cause of your problem.
I hadn't considered that these slides could be hydraulic, if that be the case, so................
Related Content
- Feb 01, 2026Community Alumni
