Mr_Mark1
Nov 23, 2017Explorer
DaisyMaggie wrote:
All 3 slide outs on my 2003 Monaco Camelot stopped working at the same time. My front slides were out so I had to hand crank them in. Is there a circuit breaker anywhere that controls all slides? if so where would it be? Could there be any other problem that anyone knows about?
DaisyMaggie, are all of your slides hydraulic? Electric? or do you have both?
I'm just going to throw this out but our 2008 Monaco Dynasty had four slides, 1 electric slide in the bedroom (bed slide) and all the others were hydraulic.
I had the same symptom as you once. On ours, and again, we had a newer model but don't leave a stone unturned.
We had a control board in the ceiling of the second bay. I had to remove a carpeted panel to locate it. We had a bad intermittent circuit board, probably from all the vibration over time. Anyway, once I pushed the connections in, it worked but I did have it replaced.
Good luck, hope you find it easily,
MM.
Related Content
- Feb 01, 2026Community Alumni
