BennieH
Nov 25, 2017Explorer
DaisyMaggie wrote:
All 3 slide outs on my 2003 Monaco Camelot stopped working at the same time. My front slides were out so I had to hand crank them in. Is there a circuit breaker anywhere that controls all slides? if so where would it be? Could there be any other problem that anyone knows about?
There is a Slide Control Board (mine is in the front electrical bay) that has 4 relays on it. There is a 15 amp fuse in the 12v distribution for it there as well. Check the fuse & Make sure that the ignition interlock relay isn't active. That will prevent the slides from operating. Some of the Monaco's also had switches on the compartment doors that will stop slide operation if they are not closed or if the switch is out of adjustment.
Related Content
- Feb 01, 2026Community Alumni
