btilfan
Nov 24, 2017Explorer
2005 alfa see ya slide ??
My brother in law is having trouble with the bedroom slide on his alfa see ya. he can't find who the manufacturer for the slide is. It's cocked. does anyone know who makes this slide?
newman fulltimer wrote:ScottG wrote:They are not a rack and pinion and his problem is not closing at the top.Only thing it can be is something is in the way of the slide
If it's a rack and pinion type, check for a broken "shear bolt" in one of the small gears located underneath and at either end of the slide. They're about 2" long by 1/4".
Sometimes just one end of a bolt will brake so you have to make sure both the head and the nut end of the 2 bolts are present.
It's also possible for teeth to break off.
