davemilster
Dec 26, 2013Explorer
OK... I started with the Right front wheel well. Looked all around, nothing but smooth panels. Went to the LF... same... opened the LF lower hatch. It appears there are some white air tubing lines passing through this compartment but I can't get to either end.... SO off to the LR... same again... smooth panels and no other items in the wheel well.
Then to the RR... there's a wire harness and connector that sure looks vulnerable being on the forward side of the wheel well. A blow out or some road debris would surely wipe out this harness... but again no pull handle cables.
Have run out of daylight to search further today. Would they be under the forward hatch on the left or right side adjacent to the genset?
38,782 PostsLatest Activity: Sep 02, 2026
