tom68's avatar
tom68
2005 georgie Boy pursuit roof leak.
Just bought from dealer. I have a leak that drips out of media cabinet above driver. it's dripping out of area between the cabinet that holds the DVD player and the Cabinet that holds TV . Where the two join togeather. I can't see any moisture in these cabinets.
I took it back to dealer to repair. Just want to know if you have any ideas where it is coming from in case it comes back later.
It's a class A
Thanks
  • The weak point for GBM's was the front cap to rubber roof joint on the passenger side. Push down lightly on that area to see if it is rotted out.
  • Gjac's avatar
    Gjac
    Explorer III
    gbopp wrote:
    Possibly a clearance light is leaking. You need to check them occasionally and reseal or replace as needed.
    That would be where I would check first. Then the front cap seam next.
  • Yep, likely a clearance light leak. It could also be a roof/front cap seam leak, but the clearance lights are a more common leak source.
  • Possibly a clearance light is leaking. You need to check them occasionally and reseal or replace as needed.
