Johno02
Mar 08, 2016Explorer
We had the same type problem with our 2005 Gulfstreme. The pass-through port was not big enough for the pipe connector to go through. I used a spare section of sewer hose, and two connectors to make an extension. Just long enough to connect to pipe on the inside, then through the port, and a connector on the outside with a cap. It only extends about 2" on the outside when stretched, so we mace a velcro strap to go across the outside holding it secure when not in use. Barely shows, and it east to connect to on the outside. Inside end stays connected to the pipe outlet. Just be sure to close valves securely after dumping.
38,766 PostsLatest Activity: Jan 10, 2026
