dougrainer
Oct 25, 2015Nomad
2008 can have Atwood electric or HWH hydraulic jacks. If HWH no pressure involved when retracted. It takes upper body strength to release the 2 springs on HWH from the mount holes. 2008 may have the pads bolted or not as HWH changed the design around that time. If also bolted, once the springs are removed you just unbolt the nut in the bottom center of the pad. Atwood, I have never seen a bent pad, so I do not know if they are replaceable. Doug
38,706 PostsLatest Activity: Jan 31, 2025
