dougrainer
Jul 21, 2017Nomad
Some model Monaco Hi Lines had an auto drivers seat module that moved the drivers seat forward when the drivers slide room was activated to keep from hitting the seat. Does your model have this feature? Doug
Per your owners manual.
SlIDe-out operatIon Slide room operation uses safety features to help prevent mechanical damage or physical harm. Slide room(s) will not operate until all safety requirements are met. To help prevent damage to the pilot seat during room operation, a seat forward function is programmed in the pilot seat. The seat will begin to move forward automatically prior to slide room activation. The seat should be moved forward manually to help ensure no contact is made.
The driver seat will move forward automatically when the slide-out switch is pressed. This feature is programmed at the factory.
To Program Seat Forward Position: Slide seat to full forward position. Press and hold the Memory Set button. Press Memory buttons 1 & 2 and release Set button. Release Memory buttons. Lights on buttons will flash three times to signal program completed
