- cgmartineExplorerSend me a PM and I will try to copy the instruction brochure for operation of the Powergear slides, but basically, you locate the slideout motor.
1. It will be either ahead of the front rail or behind the back rail.
2. Locate the two-pin connector on the slideout motor and disconnect it.
3. Rotate the lever on the backside of the motor counter-clockwise about 1/8th turn (looking from the rear of the motor). This will release the brake that holds the room in place. The room is now free to move. Using a 3/4 wrench or ratchet, crank the room, either in or out (depending on your needs, using the manual override.)
I hope this helps. - decaturbobExplorer
cgmartine wrote:
I also have a Tioga 31M. If you are referring to the fuse panel, it is below the bottom drawer, directy below the micro wave. Once you remove the door to the fuse panel, on the left hand side, you will find the breakers.
yep, it was located there above the floor. I mistook the brown panel cover for a register till I got down on my hands and knees. Mucho thanks. Do you know anything about a manual operation of slide outs? - cgmartineExplorerI also have a Tioga 31M. If you are referring to the fuse panel, it is below the bottom drawer, directy below the micro wave. Once you remove the door to the fuse panel, on the left hand side, you will find the breakers.
j-d wrote:
tobydad wrote:
Usually the breakers are located in the converter. Open the panel and you should see the 12 volt fuses and the circuit breaker switches.
If the question is "Where's the Panel?" Sometimes the "Load Center" (All in One Converter, Charger, Breaker Panel and Fuse Panel) is on the side of the bed base. If you've got a blanket or such hanging over the side or end, you may not see the Center.
nothing around the bed in our Tioga. - j-dExplorer II
If the question is "Where's the Panel?" Sometimes the "Load Center" (All in One Converter, Charger, Breaker Panel and Fuse Panel) is on the side of the bed base. If you've got a blanket or such hanging over the side or end, you may not see the Center. - tobydadExplorerUsually the breakers are located in the converter. Open the panel and you should see the 12 volt fuses and the circuit breaker switches.
38,766 PostsLatest Activity: Jan 10, 2026
