GrampaR123 wrote:
Sam Spade, I keep telling them about the simplicity of the charge line and how easy it has made things for the towing of our CRV but for some reason everyone thinks it involves "breaking into your electrical system". Nothing could be further than the truth. A simple fused line run through your harness and connected to your car battery is all it takes. Simple!! It's good to know there's at least one other person out there that understands.
Explored that option but not all MH's have a 7 pin connector. Mine has 4. Also, wiring a disconnect is about the same level of complication as running and connecting a charge wire. I have a fuse disconnect that by the looks of it should take me about 5 mins to hook up, then it's a simple matter of hitting a switch. Not really that complicated. Thanks all for the suggestions. I guess I was just a bit surprised that even without the nav, a long day can still drain the battery.
