tvchen
Nov 16, 2013Explorer
GollyCollie wrote:tvchen wrote:
Did he tell you where those other leaks are?
The one that he mentioned in particular was in the rail above the awning. He said he believed that there was entrusion happening there and that the water then traveled under the rail up to the front and then into the cap. I hope Azdel does what they say it will or those walls are in trouble.
When I saw those railings I did not have too much confidence in them so I laid a bead of dicor at the rail and roof junction. In fact I also laid a bead between the plastic trim (in front of the awning railing)up to the point where the trim meets the front cap). I also pro-flexed all the screw heads inside the rail. I believe I mentioned this in one of my earlier posts.
