Snowman9000
Nov 27, 2013Explorer
CT51,
Thanks. So, at point A on yours, the awning rail stops and a new trim rail piece goes forward from there. And the TPO roof membrane is tucked under the rails. But the sidewall is all one piece, right?
It's hard to imagine that the joint between the rails is that hard to seal, at least at the beginning. I wonder what is making it so hard. Due to the downward slope of the forward trim rail, I can see how maybe the rain is being more or less guttered into it. Then it runs down till it hits a dam, either at B or the bottom corner, after G.
For everyone:
I had to repair several leaks on a trailer, including at the trim along the roof. The trailer's trim was even less impressive than that on these MHs. But I can report some things I have learned. One is that any vinyl covering is simply water resistant, and never waterproof. It's better than nothing, which amazingly is what some manufactures use.
Next is that screws, whether covered by vinyl trim or open to the world, like my trailer's, will weep water. Not enough to fill a front cap like you guys are finding, though. Unless maybe it is a screw at a particularly bad spot, like at the closed bottom of your downward running trim. But anyway, screws will weep, even if covered by a vinyl overlay. I've taken to backing the screws halfway out, putting a pea-sized dab of Proflex RV caulk on the threads, then screwing them back in. I have not lived long enough with this band-aid to know how well it works. But it should help a lot. Someone (tvchen) in this thread mentioned doing this too.
Finally, any outside corner trim which has a leg facing at least partly upward is going to catch water and eventually let it through. This is based on the condition of the screws in the trim of the same orientation as Point C on the two fifth wheels I've had. Class C and truck camper forums are full of cab rebuilds due to leaks that started there. Fivers don't seem to be as bad, for some reason. But if you have trim that angles down in a way that catches water into the leg of the trim, or is running horizontal (like C), there is a big likelihood that water will eventually get in.
For everyone:
