luvlabs
Aug 01, 2014Explorer
sloman2001,
Amazing amount of incorrect information you get on these forums isn't it? I'm not sure why you think you need metal valve stems on your CRV, but you don't. The TST sensors can be screwed on to your existing valve stems without a problem - just make sure you take them off going through a car wash. If you are still not sure, call TST as they have some of the best customer service around and can advise you if you need to do anything.
Metal valve stems are normally used for high pressure applications like truck or motorhome tires. Your CRV with be in the 30 psi range and rubber is fine.
