Dale_Traveling
Mar 21, 2016Explorer II
Personally it would not concern me. Since Ford did not appear to change the physical characteristics of the engine (valve configuration or size, injectors, compression ratio and such) I would suspect the derating is electronic and can be regained with a tuner if desired. Probably tweaked the injector pulse timing to give a slightly smaller charge of fuel per compression cycle. Easiest and lowest cost way to meet requirements. Retooling a production line is something altogether different. Very expensive.
38,763 PostsLatest Activity: Dec 05, 2025
