GDUB1's avatar
GDUB1
2017 Winnebago 29VE wall slide question?
Was hoping that someone has experience with this model or similar? It is a 1.5hr drive to the dealer and since we purchased they have switched from a "family" owned company to CW, not quite as friendly or helpful..
Anyway, when I push the slide out button it doesn't do anything, nothing. When pressed and held a second time it moves in or out and is straight and goes to it's full extend or retract position but when it stops, I can press the button again and get just a little more out of it. When I first took it home and ran the slide it would go with the first push and then made a clicking noise when it was at full extend or retract, nothing like this now.
Any thoughts or experience with this sort of thing?
Thanks!
  • Maybe a loose wire into the switch...can you pull the switch and check the connections?
    That's where I would start.
    Next...battery fully charged?
