this may be a stupid question but i'm gonna ask it anyway. Can you run a steel wheel on the rear inside and a Alcoa aluminum wheel on the outside without any issues. I'm thinking it should be no issue...
Yes you can run steel inners and aluminum outers. Deal with a tire shop that does trucks and they will use a teflon ring between the wheels to prevent electrolisis between steel and aluminum.
