oyly's avatar
oyly
2nd LP regulator fail in 2 years - oil in regulator!!?
So my LP regulator failed again, after having been replaced less than a year ago. My mechanic showed it to me as he pulled it off. Oil came running out of it! And he thinks that's why it failed.
So now I'm wondering, how did the oil get in there???
I've been filling the tank with "Autogas", which is perhaps 80 percent butane and 20 percent propane. I don't think the butane should be a problem, it should just burn about 10 percent hotter than regular propane. I also can't find any information on the web that indicates that oil is added to the Autogas (which could have made sense, since autogas lubricates an ICE less than gasoline).
One theory I have is that Winnebago puts oil in the LP system for preservation, and that this should be drained out before using the RV?
