This is what I have. The dial sticks out of the right side. When you turn it, it moves the numbers above the "Temperature Set" arrow.
Doug, here is a link to the brochure:
http://fleetwoodrv.com/frvlibrary/docs/2008/2008_filx_b.pdf
It came with standard with 30 amp service. Even if it did come with 50 amp service, I can't fathom any reason why the previous owners would go through the hassle of converting it down to 30. They kept all of their service records, and I have scoured all of them. Not once was there a mention of doing that or of replacing the ECC.
What is weird, though, is that the manual that I have for the ECC shows a picture of it, and it is the same as mine except below the LEDs for the AC's, there is a switch that lets you pick which AC (or both) to run. Mine does't have this switch. It's just blank, as you can see in the picture.
