roadrat57ExplorerJun 22, 201630 amp rig plugged into 50 amp outletWith an adapter, can I plug my 30 amp rig into a 50 amp outlet? What I understand is, if I do not demand more than 30 amps at a time, I will not blow fuses, Somebody explain this 30 vs. 50 amp thing...Show More
Mandalay_ParrExplorerJun 22, 2016Yes, no problem plugging into 50amp. You will only draw what you need. Probably 30 max.
Related ContentElectrical outlet issues7 pin plug amperage rating?Plugging into the electric dryer outletPLug into 220 v outlet?30amp camper plugged into 110 home outlet
