DrewE
Jun 22, 2016Explorer III
ron.dittmer wrote:
Okay, Please educate the person typing this reply for I am a total idiot when it comes to these things.
I thought that 50 amp service is two 25 amp circuits. Is not the adapter providing 25 amp service? I thought using the 50 amp adapter provided less amperage than using the 30 amp service directly.
50A RV service is 50A 120/240V split phase service, so each leg is limited to 50A. It can supply a theoretical maximum of 12 kW, compared to 3.6 kW for 30A 120V RV service. With the adapter you can in practice use just as much current as with the 30A plug. (The supply is greater, but you're limited by the main breaker in the RV's panel, and using more than 30A would typically be overloading the shore power wiring in the RV anyway.)
38,769 PostsLatest Activity: Mar 31, 2026
