The answer is; it depends. Ours only has one rooftop air. It's a 15k unit. "usually" it's enough. Camped it's not really an issue. Once a few years ago we were at VA beach and daytime temps crept up to 100 and we were in full sun. It would not keep up that day, but as the day waned it cooled it back down. Travelling in those temps is also another story. You add road heat, engine and transmission heat and in 90+ degrees it won't keep up. I would prefer 2 rooftop airs and if this is a tipping point in your decision go with a coach that has two. It wasn't that critical for us and hasn't been a big deal, and the coach we wanted only had one so that's what we got. We are happy, but if you plan on travelling often in 90+ temps it may not work for you. If you are a weekender with small trips it will be fine 95% of the time. It will never be an issue when the sun goes down which is when we spend the majority of the time in our coach. The rest of the time we are out doing stuff and don't keep pets in the rv, so frankly we don't care that much. But in full sun on a hot day or travelling in a hot day, no it won't keep up. It's up to you to determine if you will be in those conditions and how often.
