Wolfganghd's avatar
Wolfganghd
300 HP Cummins shuts down
2006 Damon Astoria, Freightliner chassis 300 HP Cummins, with 35000 miles on it been no problem . Last month when started it. idled for about 1 min then shut down did this couple time then stared ok and drove home stopping and starting it a few time. Sat in the yard for home for a week went to start it...just shut down and it is now doing it all the time now....will not idled more then a min then shut down, can't even drive to have service. ???
  • ok thanks fuel pump lift pump is one of the same ??
    can't locate on the engine could be in the tank ??
  • Lift pump. Get it checked or simply replace it before you damage the HPFP by starving it for fuel.
  • Wolfganghd wrote:
    2006 Damon Astoria, Freightliner chassis 300 HP Cummins, with 35000 miles on it been no problem . Last month when started it. idled for about 1 min then shut down did this couple time then stared ok and drove home stopping and starting it a few time. Sat in the yard for home for a week went to start it just shut down and it is now doing it all the time now....will not idled more then a min then shut down, can't even drive to have service. ???
    do you have a fault code?
