two_travelersExplorerApr 20, 201730A male & female replacement plugsWhen I plug the power cord into the generator outlet in or Winnebago Vista the wire is bent at a severe right angle, because the box is mounted to low. I thought of making a short cable up with male/f...Show More
1995braveNomadApr 21, 2017You did not state if you rig is 30 or 50 amp, but check out Lowes or Home Depot they should have a straight plug that will fit.
Related Content7 pin plug amperage rating?Glow plug replacement Pleasant surpriseReplacement Lights for TT? 12-Inch Female-Female Hose - What For?30 amp male plug to 50 amp female
