- bitster98Explorer3208 in a beaver you probably got a mt 647 four speed. What does your shifter look like? If it is a toggle switch you got a air shifter. Probably a stone Bennett shifter. You got 120 psi? Forget about codes/ecu/ect ect. The air shifter will be mounted on the passenger side of the transmission. Joe.
- Mike_HohnsteinExplorerHello? The guy doesn't have a ECU coach.
- rhar1ExplorerI had this problem with my Safari 3 weeks ago. It would not go into drive someone suggested I place a heatpad on the ECU on mine it was attached to the keypad. I used a clampon light with a 75 watt bulb near the ECU and after about an hour it would shift the next morning when it was cooler it would not shift. Placed the light near the ECU and it worked again. I located a web site transmissioninstruments in
Flower Mound TX. Phone 1-866-439-0779. Called and talked to John and explained my problem. He said he could rebuild the ECU and that should take care of it. I shipped it Monday Oct.6 2nd day air it returned Monday Ocy. 13 I installed per his instructions and it works perfect now. I have driven it 2 times and it works better than I rememberfor a couple of years.The repair was $495.00 plus shipping and insurance. Please report back if this solves your problem - Mike_HohnsteinExplorerRunning low on fluid?? That's not good, torched clutch packs result in no motion. 89 Allison, probably a 600 series, essentially huge Turbo 400. Fuses won't help you.
- Gonzo11111ExplorerThanks for all the replys; I thought transmission fluid was a problem but filled it up because it was low, but no go. Transmission is an Allison 1989 variety. Am going to check fuses next. Dont think idle is a problem but will look at that right away. When I finally get it figured out and back home, I will let everyone know how it went right after I have a Bourbon in my favorite chair. Well not "in" my chair but in a glass while I am sitting in my chair :-)
- Gasman_2Explorer
Mike Hohnstein wrote:
Year of coach would really help. A 3208 is stated, doubt there are any computer issues, transmission cable problems seems more likely.
Yes with a 3208 Cat engine the Allison would not be a "world" transmission like the current models. OP what Allison do you have in the coach? I would think it would be like a MT-645. - Mike_HohnsteinExplorerYear of coach would really help. A 3208 is stated, doubt there are any computer issues, transmission cable problems seems more likely.
- TinstarExplorerDo a transmission check at your shift panel and see if you are getting any codes.
- dieselmdExplorerElevated RPM can be the result of having the cruise control turned on. If you have steering wheel controls, and you bump it... I have. Tranny will not shift in that state
- ferndaleflyerExplorer IIIThat idle deal got me ONCE. Mat had got under the back of the throttle pedal and caused a little extra idle speed. It wouldn't go into gear over a certain amount and I was over. Moved the mat and all was fine.
38,769 PostsLatest Activity: Mar 29, 2026
