- AcampingwewillgExplorer IISo Willie, you actually knew the man? That's pretty cool. The "Howard" stabilizer itself is quite the mechanical marvel. I know that they use to be big in the trucking industry also. My Vogue had this as standard equipment and as I stated, I love it.
- Cloud_DancerExplorer II
Acampingwewillgo wrote:
Not sure how popular they are nowadays, but certainly Steering stabilizers use to be recommended. I happen to have one that as far as I know, is not made any longer, "Howard Power Center Steering Stabilizer". Presumably one of the better ones ever made. Long story short, it works very well in holding you on the road with little effort. No cross wind problems, no Truck passing issues and minimal steering effort.
As I recall Blue Ox made a similar product and other manufacturers such as Steer Safe had some too.
As related previously, there are plenty of approaches available to correct such an issue...
Thanks for mentioning my ole friend Dee Howard, a true inovator. He knew quite a bit about hydraulic feedback circuits, and aerodynamics. He invented and produced a very successful thrust reverser for jet engines. He had a shop on Rhapsody St in San Antonio (not far from my place). He also had 2 large hangars at San Antonio International. He also designed a couple of stability-enhancing mods for Lear Jets. - univmdExplorerFor the above referenced rig it could be true.
- AcampingwewillgExplorer IIGuess that's what makes the Howard so good...it's is adustable and I often turn it completely off when driving in town. On the highway, I wouldn't be without it!
- IvylogExplorer IIIOften it’s the nut behind the steering wheel that needs tightening. My “new” ride had a steering stabilizer on it and I found it made driving tiring where my previous rig (same chassis) did not. It wanted to center the steering even though with a cross wind the steering needed to be off center. It also made turning the steering wheel harder so I disconnected it which got it back to what I was used to. I recently needed the steering wheel turned 45 degrees to go straight...was glad I didn’t have to fight the stabilizer too. I may make a air operated slip connection so the centering can be moved from center and reconnect it.
I would not add a stabilizer unless it is adjustable. - AcampingwewillgExplorer IINot sure how popular they are nowadays, but certainly Steering stabilizers use to be recommended. I happen to have one that as far as I know, is not made any longer, "Howard Power Center Steering Stabilizer". Presumably one of the better ones ever made. Long story short, it works very well in holding you on the road with little effort. No cross wind problems, no Truck passing issues and minimal steering effort.
As related previously, there are plenty of approaches available to correct such an issue... - janstey58ExplorerDon't these guys take the potential new units for a long test drive??
- maddog348ExplorerBad Dutch, Bad ~~ Ya beat me to it.
- ArchHoaglandExplorer
DutchmenSport wrote:
"40' Diesel Pusher wandering on the road" ????
Did it ever find it's way home? :B
Some who wander are not lost. - DutchmenSportExplorerDelete
38,778 PostsLatest Activity: Jun 06, 2026
