Sam_Spade
Dec 04, 2016Explorer
falconbrother wrote:
The battery is two weeks old. I suppose it could be bad but, seems unlikely. I'm going to run jumper cables from my car to the battery and give it a try tomorrow.
And if that doesn't work either, before you go tearing the starter apart consider removing the spark plugs to see if any fuel or oil blows out the holes when it turns over that way (the problem might be hydro-lock).
It is also possible that the contacts in the solenoid are burnt, in which case jumping at the battery wouldn't help.
38,706 PostsLatest Activity: Feb 02, 2025
