falconbrother
Dec 06, 2016Explorer II
RLS7201 wrote:
OK, you check the ground, and it's good. What about the positive side? I'll bet the generator starter cable doesn't go straight to the battery. Find all the connections between the battery and starter and make sure they are good. Is there a house battery disconnect switch?
Richard
There is no house battery disconnect that I'm aware of. I haven't traced the cable from the battery to the generator. The weather has been cold and wet. I'll get to that though. I did roll the dice and order a starter. If that doesn't fix it then whatev's.. I'd like it ready to roll on the 19th.
38,706 PostsLatest Activity: Feb 02, 2025
