DrewE
Apr 20, 2015Explorer III
Gene in NE wrote:Oldme wrote:It has been reported that the 3 valve V10 is not available in motorhomes. (comment in red added to author's posting)
Depends on what you want.
No gas RV will be great on MPG.... (if you want better gas mileage, the Chevy seems to be about 1-2 MPG better.)
Compare:
Ford 6.8 V10
2 valve version - old version
265 horsepower at 4,250 rpm
425 foot-pounds at 3,450 rpm
3valve version V10 - new version - only one availabe
Horsepower (SAE net) 362 @ 4750 rpm
Torque 457 lb.-ft. @ 3250 rpm
Ford 5.4 V8
5.4L (330 CID)
Horsepower (SAE net) 255 @ 4500 rpm
Torque 350 lb.-ft. @ 2500 rpm...
The three-valve version is not available in the E series chassis (be it a regular cargo/passenger van or a cutaway chassis for a class C motorhome or whatever) due to space limitations—the three valve heads are taller than the two valve heads, and the chassis doesn't have clearance for them. The two-valve version is not currently available on class A motorhomes (and probably most or all truck chassis models), as I understand things.
