busyguy's avatar
busyguy
7500 Onan
I posted this on IRV2 and didn't get much response. My QD7500 Onan is not on a slide and has to be dropped down to take the cover off to gain access to the engine and internal parts.
I was wondering if anyone has cut the outside cover portion off and then used hinges or brackets to re install it. Would make it a lot easier to do some maintenance on the internal workings.
Any thought on this?
Busyguy
  • I believe I'd simply drop it once and put a kevlar belt on it and be done, every thing else is done from the bottom.
  • I do all my own maintenance on my m/h. If I can spend a few hours making it easier to get to the engine on the gen set and be able to change the belt and thermostat why wouldn't it be worth it.
    Beats dropping the unit for a minor repair.
    Thanks for the replies
  • You can change the oil, oil filter, fuel filter, air cleaner, and flush coolant without removing the cover. You cannot change the belt. So, is it worth the trouble?
  • Only if it lets you change the belt. The QDs run forever until they don’t.
    They don’t usually need tweets.
