Sam_Spade
Oct 28, 2016Explorer
Sneeblii wrote:
It only hisses after being hooked up for a good period of time
Sneeblii wrote:
Red to pos black to neg. I tested reads fully charged battery
What exactly did you test that made you believe that it was fully charged ?
And what did the voltage read WHILE it was hissing ??
I mean no offense here but the wording of your posts on this subject so far indicates a lack of a good basic understanding about battery and charger systems.
I suggest that you look for the link, which has been posted a hundred times, to the basic tutorial for 12 V systems use and care. I'm sorry but I forget the name; maybe someone will post it for you again.
Failing that, you should take it to an RV repair shop and ask them to do a couple of quick tests and diagnose whether or not there is a problem......and explain to you how the 12 V system works on THAT model.
P.S. Having this same discussion in more than one thread is just confusing to everybody. You should pick ONE and stick with it.
