Mudshovel's avatar
Mudshovel
84 Shasta Motorhome Rebuild/ Repair
Hello all I'm new to this forum and after reading for 2 soild days of oldtrucker63 Dodge rebuild has really inspired me to share my project.
Here is go's....
In the begining there was a CL ad, a poorly taken care of motorhome and a dumb guy (me) willing to buy it! lol, here is what I ended up with:
1984 Shasta - unsure if there is a model name.
Built on a Ford E350 Club Van chassis powered by a 460 big block backed with a C6 transmission.
Has 103k miles and runs and drives like a champ! (except the 6 square tires)
I knew this was a project, well more like of a piece of******but have love for things like this and it turns out it was in better shape than I expected but was in serious need of repair.
The seller didn't really know much about it and had vey little to tell me. The asking price was 600.00 and I talked hime down to 400.00 and sight unseen me and my brother were off to bring it home. Well when we got there It seemed a little worse than I thought but the seller said "it fires right up and everything works......" (then the "except" part came in) but the fridge and "I can't get the genset to stay running annnnnnnd there is some impact damage to the overhead bunk, and I think one of the windows is broke. I'm thinking to myself your unsure of this? lol then the story comes out that he barrowed it to somebody and they hit a tree and his fix was a plastic tub lid and 2500 feet of blue painters tape lots of plastic and enough staples to buil a whole motorhome!! Well after walking around this thing I said sure I'll take it as that was my terms of the sight unseen 200.00 off the asking price deal we made on the phone. So I started it up and it fired right up and ran great!, then I started smelling gas and looked under and sure it was pouring all over the ground!! damn, not going to drive it home now. I made the deal anyways and he had no problem if it sat for a few days so I could fix it or get it towed. So I handed him the cash and got the paperwork and headed home.
The next day I dove back to the MH and looked into what was leaking, could not get the engine cover off due to the welded nut in the body was broke free and spun so I had to pop the rivits out of the clamp and deal with it later. The source of the leak was the accelerator pump no big deal, it was a Motorcraft version Holley and they have not changed that pump desigin in years so off with the carb and to the auto parts store. I got the pump, installed it and she was running again!! and good! prepaired it to run down the road and away I went. Had no problem this thing runs smoother than my late model vehicles. on the way home I stoped a Uhaul and filled the propane tank and made it all the way home and put in a long term parking spot in the yard, because I knew I had some work to do, lots of work to do!
Well that's the beginning, I will try to figure out how to post pic and will get a visual up!
  • Here is what the overhead looks like, this is after I removed a huge piece of plastic that was just holding water. It looks rough but the stucture damage seems to be more to the bunk floor, its strong but warped. Believe it or not the overhead walls are in really good shape, they are still stiff and sturdy even the front wall all things concidering looks to still have some good clean wood in it. When I was talking with the previous owner he said there was very little water showing anywhere in this MH up intell this happened. Good thing he stayed on top of it, huh?
    There is a window shattered and the frame is slightly bent, I know I can get a piece of tempered glass made for this for about 150ish dollars and repairing the frame is no problem but was thinking doing away with this window if I can find some siding to make it look like there was never one here, its smooth fiberglass unlike the rest of the sidding that has ribs. I have plans to roll back the roof maybe I can just get a roll of aluminum and start under the bunk and roll all the way to the back, we will see if my wallet can support that. I will also keep an eye out for a whole window assy close to what I have and just frame a replacement one in but I know one less window = one less chance for water leakage.
  • lol oh and it did have front seats, I got them out of the way as the main entry door is un usable, we'll get to that later.
  • Here are a few pics of the inside after I cleaned up most of the trash and misc camping gear and some of the cushions. Didn't think to get any of the outside as I had tarped it already but need to put a new one one at some point soon and will get them up.
  • Sounds like you are going to be fine. The nice thing about starting off at the bottom and with skills like you have if you fall it does not hurt much. When you do it the other way down is the only direction. :)
