atikovi's avatar
atikovi
'88 Southwind carburator not getting fuel
Engine wouldn't start so I took off the fuel line from the carb and cranked. No fuel coming from the line. Fuel guage is at 1/2 and I put 12 gallons in before driving it 20 miles to where it's been parked the last 2 years. Have started it regularly up until a few months ago.
Does this system have just a mechanical fuel pump on the engine ir is there more to it?
  • Sounds like varnish build up in the fuel line, I would start with the fuel filter that would be located in the frame rail ( if it's a P-30 ) passengers side.
  • I had a 87 fw pace arrow with the 454 chev in it. It had a manual pump on the engine block and a electric pump in the tank. I also had filter in the fuel line in the carb and a can type(small) in the line near back of the steps up near frame rail. Also asmall holly fuel pressure regulator in rear wheel well on the line from tank. Have to test for press at different locations. Lines rust since there mostly steel and trap in filters. When mine failed , I changed all rubber from tank foward and both filters and both pumps. Elect actualy failed.
