Golden_HVAC
Aug 06, 2015Explorer
Racorman wrote:
Also, do I need to put an inline fuse between the controller and the batteries? If so, what size fuse?
900 watts? Max that you could \get through there is about 90 amps, so a 100 amp fuse will have you covered. #4 wire is max 100 amp fuse. I guess it depends on the wire. If you are using #6 wire, then 60 amp fuse is all it is rated at.
Good luck,
Fred.
