kevfra's avatar
kevfra
'94 Dutch Star ran fine, died - that's it
This is a C-Series Cummins in a 1994 Class A motorhome. I fired it up the other day and it started Bang(!) right away like always. Ran for maybe five minutes, happy idle, then shut down. Won’t start again. It cranks great, tries hard, but not even a cough. No smoke. I suspect the fuel cutoff solenoid but I manually blocked it open and no difference. Here is one clue, as I crank there is no movement of the tachometer. Normally when cranking the tach will show a few hundred RPM but now nothing. Can’t find a single fuse or breaker that isn’t working. Ideas?
