kenwat1967's avatar
kenwat1967
98 34' Allegro - Chevrolet - Brakes
Just a few weeks ago, I got out of my RV and it started to roll. Will roll uphill or down I think and this is all when it is in park. Also, when turned off, in park, will roll.
Brake light has been on for a couple of years and stayed on after replacing all brakes but it stops great and stayed still when parked both when in park with the yellow parking break on and off.
Any ideas?
Thanks!
  • Hank I'm not going to argue with you, I just don't see how the shift lever on the steering column can activate a drum brake with such ease. And if it does, why have the parking brake lever and the transmission shift lever doing the same job?
    I can be a smart a## at times and a know it all at others but not in this case. How does the shift lever activate the drum brake? I really would like to know.
  • D.E.Bishop wrote:
    Maybe it's the flux capacitor?
    Sorry, I had to start off with that but I had to get that out of my system. Now I feel grounded.
    You said it will roll even with the shift lever in park, correct? I think it may be more than an adjustment. I haven't looked inside a transmission for decades, so things must have changed but in my 55 Merc, there was a pawl that locked the trans when in park. I don't know how it worked in '98 but I don't think that it part of the parking brake.
    No pawl, has a drive line brake, a drum brake attached to rear of trans.
  • Maybe it's the flux capacitor?
  • No actually I have not. Seemed like such a sudden thing I didn't think about it. You are talking about the drum brakes on the transmission correct? I'll check it out. Thanks for the reply!
