wbrowningExplorerApr 25, 201699 Chieftain 5.9 Cummins wont stay runingEngine was running with reduced power so I changed filters it seemed to not be picking up fuel so I changed lift pump same thing if I get system primed it will run for a few minutes then die if you p...Show More
Ranger_SmithExplorerApr 25, 2016DId you check for an air leak in the system . . . Maybe sucking some air
Related ContentCummins Hit with 1.7Billion for Emissions Defeat Devices6.7L Cummins VS 6.7L Cummins HORam Cummins/Aisin Failures86' Chieftain Acquisition34 ft 89 winnebago chieftain
