Atee
Sep 09, 2018Explorer
99 newmar mountain aire 4081 prepare for towing
Hi.
I am looking to buy a 99 newmar mountain aire 4081 diesel pusher. It's sitting under trees for more than 2 years now. Owner said someone started up the engine about 8 months ago, was running fine but did not accelerate. So they didn't buy it because of the expensive towing to 300 miles away. The whole inside needs to be redone (water damage, holes from tree branches). My plan was to move it to the rv storage next door where I could work on it. Its sitting all the way down on the ground. My question is that how could I inflate the air suspension so it lifts up without the engine running, also release brakes. For towing I need to disconnect the drive shaft Right? The towing guy who i called left saying ill be back when he seen the bus in the bushes. Never came back. That's why I am trying to prepare the bus for towing because it seems like nobody will touch it as it is sitting. I have the spartan manual but it doesn't say anything about it.
Thank you for your help.
