Jabrad_s_Papa's avatar
Mar 16, 2014
A and E awning, left side won't release
The left side of my awning won't release. I checked to see if it is hanging up on the top bracket but it doesn't seem to be. Does the release lever on the right also release something on the left?
The safety brackets are open. I can jiggle it. If I pull the awning out about a foot, ( right side only) I can give the left a few good tugs with the pole it releases.
Any thoughts?
  • Are you pretty level? So that frame is not twisting.
  • It needs adjusting. If the spacing between the top brackets is slightly off, it will do exactly as you describe. Mine was doing that, I had to hook a long tid-down strap over it and jank hard to release it. Also, sometines it did not want to stow properly. An RV tech cna fix it quickly.
