lj2654's avatar
lj2654
ABS wiring
During the evacuation for hurricane Irma I had a brake that got hot. The left front wheel ABS sensor end melted and came loose from the wheel hub. Where do you go to find these connections. I have a part number from the section that I need. Wabco is on it with a 441.032.900.0 4mm cable in a 6 foot length. The other end has two female recptacles that two pins push into.
Thanks....
1 Reply
  • From the length of the wire from the sensor you should be able to easily find the connection.
    Pretty easy to pull and install. As I recall, only takes a pair of pliers.
