yobieExplorerJun 19, 2018AC ClutchMy ac clutch is not engaging and I do not have power to the clutch. There is no direct relay/fuses that I can find, but I have check all and all are in working order. I believe the PCM controls the a...Show More
ScottGNomadJun 19, 2018You probably have a low charge. You need to fix that first before forcing the compressor to run and destroying it.
Related ContentSaving the ClutchSqueaking Clutchclutch kitISC Fan Clutch Replacement $4000+ ?New Clutch Question
