Ac engine compressor went out, will this cause debris in the hoses and the dryer? Has anyone had this problem and is it a big ticket item to fix? Thanks for any info
If it was only the pulley bearing that seized up, there should be no contamination of the system. If it was the actual compressor that seized up, there is likely contamination that will need to be flushed out
